10-20-2005 03:07 PM
I have SNMP configured on all of my internal routers with read write. Becuase I am behind a firewall I don't think this is a problem. I have 2 routers on the outside that I want to configure SNMP on. I am concerned about the security risks of doing this. I need to use SNMP. Can I configure SNMP so only a specific IP can poll the router for its information?
10-20-2005 03:16 PM
Yes, you may configure SNMP so only a specific IP address can poll the router.
Let's say your server's ip address is 10.10.10.10 and your community string is public, you would do something like this:
access-list 15 permit 10.10.10.10
snmp-server community public ro 15
10-20-2005 05:39 PM
I tried it with the following config but other hosts could poll snmp information from the router. Any ideas?
access-list 15 permit 10.1.1.100
snmp-server engineID local 8000000903000009E8A8BE81
snmp-server community Public RO 15
snmp-server enable traps snmp
snmp-server enable traps isdn call-information
snmp-server host 10.1.1.100 Public snmp
10-20-2005 05:57 PM
Assuming those other hosts were using "Public", then it should not be possible. What kind of router is this? What IOS is it running?
10-20-2005 06:25 PM
It is a 2621 running IOS 12.1
10-21-2005 03:32 AM
This looks like some kind of a bug to me.
10-24-2005 02:44 AM
Just remove the snmp config from the router once, write the config,then Reboot the router and reapply it again and check.
