SNMP to get switch bandwidth
I have a Catalyst 2955 and i cant seem to find a way to get the switchport bandwidth using SNMP OIDs values. How can i do this calculation?
Blue
Re: SNMP to get switch bandwidth
Have you looked at CISCO-C2900-MIB for this?
using c2900BandwidthUsageCurrent im able to get the overall bandwidth of the entire switch, im interested in getting the individual bandwidth for each port, thanks for the previous advice though
Are you enable http service in the switch? they has the utility to view many options, like bandwidth, vlan, status.
Exist another utility to view bandwidth. try this one.
http://www.paessler.com/ "Excellent software"
I use a program called cacti, it runs on linux and is open source. I think you should give it a shot... The PRTG program that the other user gave is a good one too but this is open source and wont bog your box down, I am watching 300+ devices and the box isnt breaking a sweat.
http://www.cacti.net/
HTH, if so pls rate..
165
