SNMP Trap definition for c6kxbar
snmp-server enable traps c6kxbar intbus-crcexcd intbus-crcrcvrd swbus
Can someone explain what this trap does? I cannot find an explanation on CCO
thanks
1 ACCEPTED SOLUTION
Re: SNMP Trap definition for c6kxbar
These traps are only applicable for crossbar switching fabric modules.
This command controls the following traps from the CISCO-CAT6K-CROSSBAR-MIB:
cc6kxbarIntBusCRCErrExcdNotif
cc6kxbarIntBusCRCErrRcvrdNotif
cc6kxbarSwBusStatusChangeNotif
The description of these objects is as follows:
cc6kxbarIntBusCRCErrExcdNotif NOTIFICATION-TYPE
OBJECTS {
entPhysicalName,
entPhysicalVendorType
STATUS current
DESCRIPTION
"A cc6kxbarIntBusCRCThreshExcdNotif notification
is sent by the system when the system has
detected that the internal bus CRC error on
a physical entity (such as a module) as specified
by entPhysicalName has exceeded the fatal threshold."
::= { ciscoCat6kXbarMIBNotifs 2 }
cc6kxbarIntBusCRCErrRcvrdNotif NOTIFICATION-TYPE
OBJECTS {
entPhysicalName,
STATUS current
DESCRIPTION
"A cc6kxbarIntBusCRCErrRcvrdNotif notification
recovered as the internal bus CRC error on
specified by entPhysicalName has fallen below
the normal threshold."
::= { ciscoCat6kXbarMIBNotifs 3 }
cc6kxbarSwBusStatusChangeNotif NOTIFICATION-TYPE
OBJECTS {
cc6kxbarSwBusSwitchingStatus,
cc6kxbarSwBusFailureDuration
STATUS current
DESCRIPTION
"A cc6kxbarSwBusStatusChangeNotif notification
is sent by the the device when there is change
in switching status of the switching bus as
monitored by cc6kxbarSwBusSwitchingStatus."
::= { ciscoCat6kXbarMIBNotifs 1 }
Thanks for the quick reply. Is this used for just the fabric module or also for the sup720?I have all new sup720s and trying to find out if this is needed going forward.
693
