You may experience some slow load times, errors, and slight inconsistencies. We ask for your patience as we finalize the launch. Thank you.
snmp trap syslog
If I apply snmp-server enable traps syslog and the trap will be sent to HP OpenView NNM server, dod I need to specify the syslog server again with the command?
Thank you!
  • Network Management
2 ACCEPTED SOLUTIONS
Red
Re: snmp trap syslog
You would need to specify the HP OV NNM's ip address in the snmp-server host command as well.
Red
As long as there is a route from the device to the new NNM server, it doesn't mater whether you have the trap-source or not.
Red
So my configuration would be as follows for syslog traps. other snmp parameters are configured
snmp-server host 2.2.2.2 version 2c qqq
logging history level 0
Are this all for syslog traps?
Thanks!
Red
That should do it. To be on the safe side, you may want to do this:
snmp-server host 2.2.2.2 version 2c qqq syslog
Thank you!
Another question is our management is migrating from one NNM server to another. after the new server fully functions, the old one will be removed. so during the migration, two NNM server will co-exist. The ip addresses of the old and new NNM server are in different subnet. The issue is on some rotuers/switches, the command of snmp-server trap-source is applied. In this case, will the traps be send to the new NNM server also, or I need to remove this command.
Red
that helps! Thank you!
356
