03-15-2006 05:04 AM
I do not understand what does it mean this trap : "ttySends Cisco enterprise-specific notifications when a TCP connection closes"
When i enable this trap, i received some thousands of syslog :
"20060303 133708 SNMP 10.52.49.134 Trap(tcpConnectionClose) tslineSesType.194.1=5 tcpConnState.10.52.49.134.23.10.52.49.4.1495=0 loctcpConnElapsed.10.52.49.134.23.10.52.49.4.1495=200 loctcpConnInBytes.10.52.49.134.23.10.52.49.4.1495=1 loctcpConnOutBytes.10.52.49.134.23.10.52.49.4.1495=346 tsLineUser.194 Addr:10.52.49.134 Int:6 Int:1 Tick:"179 days 22:46:24"
I do not see in which case is it interesting to get this syslog ?
Someone could help me ?
Thx.
nico.
03-16-2006 06:23 PM
This is the definition of this SNMP trap (not syslog):
tcpConnectionClose OBJECT-TYPE TRAP
VARBINDS { tslineSesType, tcpConnState, loctcpConnElapsed, loctcpConnInBytes, loctcpConnOutBytes, tsLineUser }
DESCRIPTION "A tty trap signifies that a TCP connection, previously established with the sending protocol entity for the purposes of a tty session, has been terminated."
You may get a description of each of the varbinds by entering them in the SNMP Object Navigator:
http://tools.cisco.com/Support/SNMP/do/BrowseOID.do?local=en
If you are not interested in this information, then disable the trap.
03-17-2006 07:38 AM
Thx Nhabib,
but i do not understand, what does it mean "the sending protocol entity for the purposes of a tty session" : what is a "protcol entity" ?
Is-it telnet connection (= tty session) to the router (for configuration ) ? or telnet connection which go throught the router ? why does my customer get 10 tty trap/minutes ?
Thx in advance.
Nico.
05-07-2007 10:15 AM
I have activated snmp tty traps but when I try a
ssh connection it does't generate snmp traps...
as I understand ssh generates a tcp connection as telnet does.
But when I start a telnet session it works all rigth...
What could be happen??
I am working with a cat 3560 with secure version IOS...
Thanks!
05-07-2007 10:36 AM
This is a known bug that tcpConnectionClose traps are not sent for SSH sessions. See CSCsg99865. Currently, this occurs because the OLD-CISCO-TS-MIB does not support SSH sessions. Specifically, the tslineSesType does not have an ssh type. There is currently no ETA on when this will be supported. Since the OLD-CISCO-TS-MIB is deprecated, this may not ever happen. However, there is a CISCO-SECURE-SHELL-MIB that can be used to manage SSH sessions. Support for this MIB depends on the exact IOS image running on your device.
