Hi guys.
I am re-configuring some routers to generate traps for our new monitoring tool.
I have noticed that after I applied the snmp trap configs that we are getting traps for PRI channels (30 voice channels), which I wouldn´t like to. This happens when users are using the voice channels on demand. When they hang up, the used channel goes down and I get a trap.
Basically, regargint the controller, the only interface that I must monitor is the signaling one (my case is the channel 0/3/0:15) or if the entire controller goes down.
Below, the snmp trap config:
snmp-server ifindex persist
snmp-server trap-source Loopback0
snmp-server enable traps snmp linkdown linkup coldstart warmstart
snmp-server enable traps envmon
snmp-server enable traps isdn layer2
snmp-server enable traps isdn chan-not-avail
snmp-server enable traps isdn ietf
snmp-server enable traps bgp
snmp-server enable traps hsrp
snmp-server enable traps ipsla
snmp-server enable traps voice poor-qov
Could you please help me to figure out how I can solve this?
Also, if you guys have any other advises and more ways to monitor the voice environment.
Thanks in advance
