You do not want a Cisco device to send all of the SNMP traps that the device knows how to send. For instance, if you enable all traps in a Remote Access Server with 64 dial-in lines, you get a trap whenever a user dials in and whenever a user terminates the connection. This creates too many traps. Cisco IOS Software defines groups of traps that you can enable or disable.
