SNMP
We currently have snmp v1 on some Switches. How do I get them up to Version 2 or 3? Thanks
We have C6509 running 12.2(18)SXF4
and Cat 4003/6 running Cat OS 6.4(10)
Also on the above switches have the line
snmp-server host x.x.x.x public.
If and when I do change the snmp public and private, do I also need to change this line to the modified value?
Blue
Re: SNMP
> If and when I do change the snmp public and > private, do I also need to change this line > to the modified value?
Practically no NMS software seems to bother checking the incoming SNMP trap's community string, so you'll find it makes no difference changing it or not.
Re: SNMP
If you want to enable v2c in this case you would configured something like:
snmp-server host 1.1.1.1 traps version 2c public
For SNMP V3, have a look at this link:
http://www.cisco.com/en/US/products/sw/iosswrel/ps1830/products_feature_guide09186a00800878fa.html#wp17413
Re: SNMP
What effect will my changing the
snmp-server community secret RW. The secret part to something else. As in all the Cisco examples, it was left as is.
SHould I change it or not. and what effect will changing it have and what is it used for?
THanks
Red
Re: SNMP
Yes, you should change it to something more secure. public and private are simply used as examples. You shouldn't have public and private as your community strings.
117
