Snmp
Hi All
Will enabling snmp on a Cat2960 acting purely as a L2 switch afftec performance?
We want to remove as much as possible any overhead on the switch so have turned off as much as we can.
Silver
Re: Snmp
I don't know if it is possible to do that on
Cat2960 because the command "sdm prefer vlan"
is NOT available in Cat2960, only with
Cat3550:
C2960(config)#sdm prefer ?
default Default bias
qos QoS bias
CCIE Security
Re: Snmp
Thanks, I was asking about snmp. What is sdm? Thanks
Re: Snmp
Where do you have performance concerns? Running services will increase CPU/memory but should not effect port performance.
107
