SNMPv3 config question
Hi there,
I'm trying to configure snmpv3 on a 26xx with authpriv but the "priv" option is not available:
swatm(config)#snmp-server group v3group v3 ?
auth group using the authNoPriv Security Level
noauth group using the noAuthNoPriv Security Level
I'm running the following image:
c2600-i-mz.123-26.bin
Is it a question a feature set ?
1 ACCEPTED SOLUTION
Re: SNMPv3 config question
Yes. You need a crypto image (one with k9 in the feature set name) in order to support SNMPv3 authPriv. With IP ONLY, you'll only be able to do authNoPriv.
Makes sense. Thanks a lot for the fast answer !
162
