Community Member
SNMS 1.5 & 1801
Hello, I have a SNMS 1.5 and I have installed packages 7.0 for Rtr1800. When I start discovery on WhatsUP Gold it seams that i doesn't see the Cisco 1801 on the network. It show it as a standard Router Icon. device Type 1802 doesn't exist on General propreties of the devices but as above I have installed devices packages 7.0 on SNMS application.
Does someone know why 1801 is not on devices types or can't be discovered by WhatsUP ?
1 REPLY
Bronze
Re: SNMS 1.5 & 1801
You can discover your network using any of these methods:
• Discover with SNMP SmartScan. (This is the preferred method).
• Discover using ICMP.
• Discover from your Network Neighborhood.
• Import from your registry.
• Import from a hosts file.
The procedure to discover your network with SNMP SmartScan is described in the below URL:
http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_small_network_management_solution/1.5/installation/guide/setup.html#wpmkr1122336
89
