Webcast-Catalyst9k
SNMS 1.5 > Problem Netconfig with 2960-TT
I cannot change the 2960-TT's configuration with Netconfig in SNMS, i have put the last version of this product, the last IDU and the patch CSCse25066-1.zip,
Thanks a lot,
Re: SNMS 1.5 > Problem Netconfig with 2960-TT
What error are you getting? What type of config change are you trying tp push?
There is not error but the equipement is not viewing when i want to configure it
This problem block my client?
Can you find an issue?
Thanks a lot...
Can you upload a screenshot of what you are seeing?
Are you saying the device isn't in the list?
I dont see the equipment in the list. The screenshot will not show only the other equipment.
Can you help me for this problem or not?
Thanks a lot for your comprehension
I attached the patch obtained from TAC.
Maybe will help.
Cristian
140
