SNMS 1.5 Problem RME with 2960
I cannot manage the switchs with RME SNMS 1.5, the updates were made. Is there a solution to this problem?
Thanks a lot
Re: SNMS 1.5 Problem RME with 2960
Looks like the 2960's aren't supported in RME 3.5 for SNMS
http://www.cisco.com/univercd/cc/td/doc/product/rtrmgmt/cw2000/cw2000e/e_3_x/3_5/e3_5.htm
Even with the latest IDU it seems to be missing, however, there is a patch available from TAC.
The patch can be provided as the fix for bug CSCse25066 which adds this 2960 support.
Hello Davistan
I cannot find bug CSCse25066. Could you please provide a link for the bug/fix? thanks.
Looks like its an internal bug that doesn't have info made available on the bug toolkit. I'll see if I can update it so its viewable online.
95
