SNMS upgrade from 1.5.0 to 1.5.1 (CSCsa38828)
What should be the next step as I am hitting this bug and the workaround doesnt suggest anything.
CSCsa38828 - Installing of Win2003 image on top of Update1, aborts the installation
Symptom:
SNMS 1.5 install aborts with an error message "CiscoView is already installed in your system. SNMS install will abort. Please uninstall CiscoView and try again."
Conditions:
If Customer is trying to install the product in the following scenario then install will abort with an error message.
SNMS 1.5 + RME IDU v5 + SNMS Update 1 + SNMS 1.5
Workaround:
No workaround available. This is not a supported installation path for SNMS 1.5.
  • Network Management
115
