Span Port - Packets not being received by dest port
My SPAN port, 4/47, doesn't seem to be receiving any of the packets that are being received by port 4/48 (note input packets in the show commands below.) What am I doing wrong?
DO-MDF-CAT6509#sh mon sess 1
Session 1
Type : Local Session
Source Ports :
RX Only : Fa4/48
Destination Ports : Fa4/47
DO-MDF-CAT6509#sh int fa 4/48
FastEthernet4/48 is up, line protocol is up (connected)
Hardware is C6k 100Mb 802.3, address is 0003.6c2a.06ff (bia 0003.6c2a.06ff)
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
reliability 255/255, txload 1/255, rxload 11/255
Full-duplex, 100Mb/s
input flow-control is off, output flow-control is unsupported
Last input never, output 00:00:27, output hang never
Last clearing of "show interface" counters 22:01:55
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 4508000 bits/sec, 459 packets/sec
5 minute output rate 765000 bits/sec, 320 packets/sec
8566485 packets input, 7895865618 bytes, 0 no buffer
Received 64761 broadcasts, 0 runts, 0 giants, 0 throttles
7862325 packets output, 4134332929 bytes, 0 underruns
0 lost carrier, 0 no carrier
DO-MDF-CAT6509#sh int fa 4/47
FastEthernet4/47 is up, line protocol is down (monitoring)
Hardware is C6k 100Mb 802.3, address is 0003.6c2a.06fe (bia 0003.6c2a.06fe)
reliability 255/255, txload 11/255, rxload 1/255
Last input never, output 2w1d, output hang never
Last clearing of "show interface" counters 22:02:11
5 minute output rate 4552000 bits/sec, 463 packets/sec
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
8573761 packets output, 7904194606 bytes, 0 underruns
Silver
Re: Span Port - Packets not being received by dest port
Show int fa 4/47 shows that Line is down which means clock rate may not be configured proper;y on this LAN segment.Layer 2 Encapsulation may also mismatch.
Carlos:
Although I have SPAN setup on a different platform than the original poster, the status on my device is the same, and I have no issues with SPAN.
c2950#sh int fa0/1
FastEthernet0/1 is up, line protocol is down (monitoring)
It looks to me like your span port is receiving traffic just fine. You are spanning the RX only traffic from fa4/48 to span port fa4/47. If you look at the input rate on fa4/48 (4508000) it is very close to the output rate on your span port fa4/47 (4552000). The difference is because the ports are on two different five-minute average cycles.
Hope this helps.
-rb
Chris:
Ron's observation seems valid.
Are you drawing this conclusion because of a mis-configured sniffer (non-promiscuous mode, capture or display filters in use)?
What sniffer software are you using. If snifferpro make sure that someone did not change the default info while setting up a trace. Make sure that you can run an open trace with no source or destination IP set up in the filter
SPAN destination ports are down by design, so don't worry about that.
http://www.cisco.com/en/US/products/hw/switches/ps708/products_tech_note09186a008015c612.shtml#charac_dest
"The state of the destination port is up/down by design. The interface shows the port in this state in order to make it evident that the port is currently not usable as a production port."
Try to use another sniffer, wireshark (a continutation of Ethereal) is nice and free.
Farrukh
403
