Community Member
Specific OID question -
What is the specific OID for a Cisco 3660 rtr?
I see how to get the value when I snmpget system.sysOjbectID.0 but don't know what that translates to. Can someone help me out?
johnsonr@nmscrme01 > snmpget host1.domain.org public system.sysObjectID.0
system.sysObjectID.0 = OID: enterprises.9.1.205
I would think it is .1.3.6.1.4.1.9.1.205 but when I try to snmpget that specific OID, nothing comes back so I'm doing something wrong.
Re: Specific OID question -
Walking the sysObjectID is the correct way to get the value. You would then use the snmp translate tool to get the text value:
http://tools.cisco.com/Support/SNMP/do/BrowseOID.do?local=en
OID 1.3.6.1.4.1.9.1.205 = cisco3660
Community Member
OK. When I snmpget host1.domain.com public system.sysOjbectID.0 - it returns enterprises.9.1.205 - again this is a 3660 rtr.
I then put this into the oject translator and it returns 1.3.6.1.4.1.9.1.205 -
My question is: why can I NOT do an snmpget on that specific OID of 1.3.6.1.4.1.9.1.205 -
When I do it, I get:
johnsonr@nmscrme01 > snmpget host1.domain.com public 1.3.6.1.4.1.9.1.205
Error in packet
Reason: (noSuchName) There is no such variable name in this MIB.
Failed object: system.sysUpTime.6.1.4.1.9.1.205
I though I knew this stuff so thnks for helping me understand.
.205 is the value returned, it is not an object that can be queried specifically.
It would be like querying ifInOctets and then doing an snmpget for ifInOctets.1.1008973 (1008973 being the returned value)
.205 is not an index, it is a value returned based upon the CISCO-PRODUCTS-MIB
179
