04-08-2010 10:31 AM
Hi ask the expert team!
I want to know if the device SRW224G4 24-Port 10/100 is compatible to CWLMS. Because I can´t reach from CW server.
The CW say that the credentials are wrong. Attach the screen shot.
Thanks very much in advance!
Best regards!
Solved! Go to Solution.
04-08-2010 04:52 PM
While Cisco did buy Linksys, they are still a mostly separate entity in many regards. The Linksys product line is geared toward home and SMB use where as LMS is currently targeted as an enterprise management application. That said, SMB devices like the SRW224G4, and even the Catalyst Express 500 are not supported by LMS. This could change in the future, but not in the short term.
Please support CSC Helps Haiti
https://supportforums.cisco.com/docs/DOC-8895
04-08-2010 11:54 AM
Since that's really a Linksys switch, I doubt LMS will ever support it.
04-08-2010 12:24 PM
04-08-2010 12:48 PM
Right, but I would expect to see the Cisco Catalyst Express 500 series becoming supported in LMS, before anything "Linksys by Cisco". Neither is, today.
04-08-2010 01:12 PM
ok, thanks for your explanation. Mean taht this switch SRW224G4 not run CDP protocol ?
thanks very much!
04-08-2010 04:52 PM
