Webcast-Catalyst9k
SSH failed to device
Hi Team
when i am trying to access the swich though SSH, its getting failed, Plse find the attached screenshot for the same.
Even we are able to SSH from Putty.
LMS 2.6
Vaibhav
Re: SSH failed to device
Please verify configuration fetch protocol and package version.
Hope this helps.
Regards.
Andrea
This shows nothing about SSH. It looks like you ran a Device Credential Verification job, and only selected telnet. Re-run the job, and choose SSH, and Enable by SSH, and see if that works.
Hi Clark
where we need to choose SSH and where to enable SSH to get access of device only through SSH.
Vaibhav
You choose the protocols to test when creating the Device Credential Verification job. There will be a series of checkboxes.
To make sure RME only uses SSH, you have to set your protocol orders accordingly under RME > Admin > Config Mgmt > Transport Settings.
Hi Clark
We can do that but let me know if on other devices where ssh not configured than weather we are able to add them or not.
Vaibhav
If you need to support other protocols, add them to the protocol order lists after SSH. That way, SSH will be tried first, and if it fails, then RME will fall back to other protocols.
Hi Clark
Thanks a lot..
Vaibhav
173
