11-24-2008 12:05 PM
Hi jclarke,
Browsing through the threads I saw that a solution was posted for LMS 2.6. Looks like the issue is with the version of java. The version I've got running is 1.6.0.50 and I'm now seeing anywhere where I can type in the command with the path to the ssh client. Could you please help!
Thanks.
11-24-2008 12:20 PM
You don't with Java Web Start. Instead, you need to create a campus.properties file in your home directory on your client. This file should have one line:
CMSSH=PATH_TO_SSH
Where PATH_TO_SSH is the fully-qualified path to your SSH client. For example:
CMSSH=C:\\PuTTY\PuTTY.exe
After doing this, restart your browser.
11-24-2008 12:20 PM
I should also add that you'll need Campus Manager 5.1.1 in order for this to work properly. CM 5.1.1 is downloadable through Common Services > Software Center > Software Update.
11-24-2008 12:55 PM
Hi jc,
Ok now downloading 5.1.1. I have version 5.1.0 running What are the java config though?
Bevan
11-24-2008 12:59 PM
There is nothing that needs to be configured Java-wise. You just need to be using Java 1.6.0_5.
11-24-2008 01:05 PM
Going to test this out in a few mins as 5.1.1 is still downloading. How would LMS know which ssh client to use?
11-24-2008 01:06 PM
It knows because you tell it in the campus.properties file I mentioned previously. LMS will use that SSH client. This file is configured on a per-user, per-client basis.
11-24-2008 01:09 PM
Sorry only now seeing that previous post.
11-24-2008 01:10 PM
I had a typo. The example should read:
CMSSH=C:\\PuTTY\\PuTTY.exe
11-24-2008 01:14 PM
Cool...I'll give this a go in a bit and let yu know how I get on. The software update failed so had to start it again.
11-24-2008 02:00 PM
Thanks JC! All is now well.
Loving the service by the way!
Bevan
