09-19-2007 05:46 PM
hi
i have 3750 stack switch and when i do archive it is failed and i have this message when i click fail archive.
"CM0056 Config fetch failed for <switch name> Cause: CM0204 Could not create
DeviceContext for 77 Cause: CM0206 Could not get the config transport implementation for <ip of switch>Cause: UNKNOWN Action: Check if required device packages are available
in RME. Action: Check if protocol is supported by device and required device package is installed."
i use transport setting in rme such as Telnet, TFTP, SSH in order. i can also telnet the switch from the LMS server.
anybody knows what's the cause? i am using LMS version 2.6. thanks
09-19-2007 07:39 PM
Please provide the list of contents of the NMSROOT/MDC/tomcat/webapps/rme/WEB-INF/lib/pkgs and NMSROOT/www/classpath/com/cisco/nm/xms/psu/pkgs/rme directories.
09-19-2007 09:42 PM
hi,
i see 3750 zip file inside both directories.what more can i look for?my one is stack ones which combine 2 X 12- port 3750 and 1 X 24-port 3750. we use the same configuration,setting,ios version for all stack switches but only these two have problem of saving archive.thanks.
09-20-2007 10:32 PM
hi,
any update for this?i tried a few times to get the archive configuration but no avail.i see 3750 zip package inside the folders. thanks
