Community Member
standard credentials not present
i have several hundred switches, to which i wish to edit the configs via Netconfig.
i have checked the standard credentials of a sample number of devices via common services\device & credentials\device management - these devices only have the snmp read string.
1) is this the reason why Netconfig jobs will not work?
2) can i configure CiscoWorks to auto update the standard credentials of each device during the next scheduled device discovery, or must i do this manually for each device?
Running LMS 2.5
Thanks in advance
gary
1 REPLY
Re: standard credentials not present
You're going to some sort of mechanism to edit the config. SNMP RO will only read snmp objects, it will not perform a set. You'll need SNMP RW as well or use telnet.
Are you receiving any error?
Under your transport settings for Netconfig what do you see?
252
