Standby ip and Template
Hello All,
Thanks in advance to those who even read this topic and Many thanks to those who will reply. Here is my problem:-
I have to search for devices which do not have standby ip authentication setup. I have tried multiple permutation and combinations to setup a template both basic and advanced to match the standby <group number> ip authentication command in device config. But sadly all devices show as compliant.
Can someone help me with making a template to achieve this?
Many thanks
Everyone's tags (1)
Re: Standby ip and Template
Do you mean the "standby authentication " command?  It would be helpful to see a current running config to know exactly what you want to match on.  I'd also like to see one of your existing templates to get a better idea what you're trying to do.  In my head, I'm picturing something like:
Submode : interface [#GigabitEthernet.*#]
Body:
+ [#standby 1 authentication (md5|text) .*#]
Pretty close, you almost read my mind except that i would like
a) to check all physical and virtual lan interfaces.
b) to check all vlans/inetrfaces in each switch
my template is pretty much as you thought except that i am using
interface [#*#]
+ standby [#*#] authentication [#*#]
Well, that will not work as you are not using proper regular expressions.  Try:
Submode : interface [#(Vlan|.*Ethernet).*#]
Body:
+ [#standby \d+ authentication .*#]
204
