04-04-2007 06:21 AM
Posted by: romainpage - Apr 4, 2007, 3:03am PST
I have just figured out that the "CISCO-STACK-MIB" was not supported by the Cat4K IOS, is that possible to confirm me this ?
As a result, how can I monitor the status of my standby sup on a Cisco 4500 ?
Thanks.
Best regards,
Romain
Solved! Go to Solution.
04-04-2007 08:21 AM
You can use the cefcModuleTable from the CISCO-ENTITY-FRU-CONTROL-MIB. It will give you both admin and oper status for your Cat4KIOS modules.
04-04-2007 08:21 AM
