Community Member
starting and stoping crmdmgtd service
When I try to use "net stop crmdmgtd" service command from cmd prompt, I get 'net' is not recognized as an internal or external command.
Re: starting and stoping crmdmgtd service
What platform are you using?
If windows, post the output of 'path'
Community Member
It's win2k3.
Community Member
It's installed in D:\prog~\CSCOpx
Post the output of 'path' command from ms dos prompt
Community Member
PATH=D:\PROGRA~1\CSCOpx\objects\smarts\lib;D:\PROGRA~1\CSCOpx\objects\smarts\bin;D:\PROGRA~1\CSCOpx\campus\bin;D:\PROGRA~1\CSCOpx\MDC\tomcat\bin;D:\PROGRA~1\CSCOpx\MDC\Apache;D:\PROGRA~1\CSCOpx\MDC\jre\bin;D:\PROGRA~1\CSCOpx\MDC\bin;D:\PROGRA~1\CSCOpx\lib\jre\bin\server;D:\PROGRA~1\CSCOpx\objects\db\win32;D:\PROGRA~1\CSCOpx\bin;D:\PROGRA~1\CSCOpx\objects\wfengine\Program\procsys;D:\Program Files\Nmap
the net command is in /windows/system32/
Do you have a net.exe file there?
/windows/system32/ is missing from your path.
300
