stpxFastStartPortIndex
we are trying to set the port fast mode via SNMP. The method used to do this gets the ifDescr passed. This method does now the following steps to set the port fast mode:
This works fine for ports, which have the dot1dBridge support (i assume all trunk and 'auto' mode ports) but fails for access ports (switchport mode access) because there are no dot1dBridge objects for these ports and therefore we have no link between the ifIndex/ifDescr and stpxFastStartPortIndex.
Because port fast has nothing to do with Trunk/no trunk ports, i guess this is an error in the MIB (description?). Are there any other MIBs which uses the same index as stpxFastStartPortIndex that we can use to retrieve it?
Version:
C2960 Software (C2960-LANBASEK9-M), Version 12.2(58)SE2, RELEASE SOFTWARE (fc1)
Thanks, Michael
Everyone's tags (2)
219
