Strange snmpwalk result from ciscoworks
I used snmp walk tool from Device Center of Ciscoworks, and I got the following strange result:
.1.3.6.1.2.1.3.1.1.2.1.1.192.168.100.1 = STRING: "...BT¬".
The strange characters inside " " should be the MAC address for the host 192.168.100.1 obtained from the ARP table.
I also used other snmpwalk tool instead of ciscoworks, and I got the correct result.
The reason for me to do snmpwalk is that I cannot find a single host from User Tracking at Campus Manager. Is the strange snmpwalk result related to the failure of User Tracking? Can anyone help me out?
Thanks.
1 REPLY
Bronze
Re: Strange snmpwalk result from ciscoworks
not sure of the issue, may be you can check out the following troubleshooting link :
http://www.cisco.com/en/US/products/sw/cscowork/ps563/products_tech_note09186a0080094949.shtml#ts2
213
