Blue
stray IPMDB.db?
Without fail, there's always a copy of IPMDB.db left in the / file system after restorebackup on LMS 3.1. Is this file needed?
Re: stray IPMDB.db?
No.
Blue
Re: stray IPMDB.db?
Is this an oversight in restorebackup.pl that it does this? We have limited space in /, so this runs the risk of filling it up.
Re: stray IPMDB.db?
The old IPM data is cleaned up at the very end of the data migration process. However, there appears to be a bug with this. The code is looking for something like /backups/0/ipm/IPMDB.db. However, I believe the actual structure is /backups/0/ipm/database/IPMDB.db. However, I have no idea how a copy of IPMDB.db could end up in /.
Blue
Re: stray IPMDB.db?
This sounds rather similar to my previous issue where restorebackup.pl was looking for ani.db in /backups/0/campus/database/, but wrapper.pl had it in /backups/0/cmf/ani.db, because of messed-up /opt/CSCOpx/backup/manifest/cmf/database/cmf.txt and /opt/CSCOpx/backup/manifest/campus/database/ani.txt.
Here's the source LMS(2.6)'s /opt/CSCOpx/backup/manifest/ipm/database/ipm.txt
"ipm.txt" 2 lines, 44 characters
[ipm]
root=/opt/CSCOpx/databases/ipm/ipm.db
Re: stray IPMDB.db?
This is right. A problem with the manifest file would also not explain how a copy winds up in /. But as I said, I believe there is a bug in which the old IPM database will not be cleaned up after migration.
Blue
Re: stray IPMDB.db?
Could there a fix be [made] available for this bug?
Re: stray IPMDB.db?
I would need to know the actual layout of the ipm backup directory first (i.e. an ls -alR).
Blue
Re: stray IPMDB.db?
Attached is the layout of ipm produced by wrapper.pl:
Re: stray IPMDB.db?
Yes, this is a bug, and I can provide a fix if you open a service request.
Blue
Re: stray IPMDB.db?
Thanks. Is there a bug ID I can make reference to?
Re: stray IPMDB.db?
No, and the more I look at the code, I don't think this fix is really needed. It certainly wouldn't clean up an IPMDB.db in /. Can you identify where exactly in the migration process this /IPMDB.db gets created?
Blue
Re: stray IPMDB.db?
How precise does the identification have to be? Would the migration.log plus the timestamp of IPMDB.db suffice?
Re: stray IPMDB.db?
Maybe. It would have to be fairly precise to track down the exact bit of code that is causing the problem.
228
