Community Member
summary active open call legs on MGCP gateway in snmp
I'm busy searching for the correct OID (and MIB table) to get the summary of all active open call legs on the MGCP gatway.
When you issue the "sh voice call status" command,you get this output:
MONVGWBEL03# sh voice call status
CallID CID ccVdb Port DSP/Ch Called # Codec Dial-peers
0x2EF8C 315F 0x82C2F1B4 0/0:15.26 0/1 *8713870861 g711alaw 2001/1
0x2EF9A 345F 0x82C2F1B4 0/0:15.28 0/1 *7068221138 g711alaw 8001/1
0x2EFA4 355F 0x82C2F1B4 0/0:15.27 0/1 *3145558248 g711alaw 2001/1
0x2EFB7 24A6 0x82C2F1B4 0/0:15.0 0/1 25469718 None 1/2001
4 active calls found
Anyone an idea how i can define the snmp-get for this?
Thanks for some feedback.
Kurt
Silver
Re: summary active open call legs on MGCP gateway in snmp
There are numerous MIBs that contain voice call statistics. These include:
DIAL-CONTROL-MIB
CISCO-DIAL-CONTROL-MIB
CISCO-VOICE-COMMON-DIAL-CONTROL-MIB
you can search in these mibs for more info.
Community Member
did anybody ever figure out the answer to this?
Thanks!
195
