Community Member
Supported browsers...
Using Cisco Prime 4.1 and it looks like garbage in Safari. Any chance that there is browser support besides IE? Search did not give any results
1 REPLY
Hall of Fame Super Silver
Re: Supported browsers...
Firefox is also supported. Versions 4 and 5 are the tested ones (per Cisco here) but my experience is the later versions work fine too.
You should stick with the Java version 1.6.0(24) they recommend. When I put on 1.7, I had to back it out because it broke the Java applets (i.e., Topology).
Hope this helps.
338
