07-26-2013 04:40 AM
I have a Cisco 3725 router in my lab setup. It is having a faulty fan & every 30s below syslog message appear & fill up my logs.
Jul 26 11:19:38.637: %FAN-3-FAN_FAILED: Fans had a rotation error reported.
Jul 26 11:20:08.639: %FAN-3-FAN_FAILED: Fans had a rotation error reported.
Jul 26 11:20:38.640: %FAN-3-FAN_FAILED: Fans had a rotation error reported.
Jul 26 11:21:08.642: %FAN-3-FAN_FAILED: Fans had a rotation error reported.
Jul 26 11:21:38.644: %FAN-3-FAN_FAILED: Fans had a rotation error reported.
Jul 26 11:22:08.646: %FAN-3-FAN_FAILED: Fans had a rotation error reported.
Jul 26 11:22:38.647: %FAN-3-FAN_FAILED: Fans had a rotation error reported.
Jul 26 11:23:08.649: %FAN-3-FAN_FAILED: Fans had a rotation error reported.
Jul 26 11:23:38.650: %FAN-3-FAN_FAILED: Fans had a rotation error reported.
Jul 26 11:24:08.652: %FAN-3-FAN_FAILED: Fans had a rotation error reported.
Is there any way to suppress this log message (knowing I do not want to take any action about this failure) or not to generate a syslog for this particular faulty ? . Since I want to do debuging frequently do not see a way to get rid of this by changing the logging level.
Rasika
Solved! Go to Solution.
07-26-2013 10:53 AM
If your IOS is relatively recent, you can use the "logging discriminator" feaure in Embedded Syslog Manager.
Here is the Command Reference section covering that feature.
Here is an example I did on a switch that was reporting MAC flapping due to the behavior of a 3rd party firewall cluster that I couldn't modify:
logging discriminator FLAP severity drops 4 facility drops MACFLAP msg-body drops flapping
logging buffered discriminator FLAP 51200
logging console discriminator FLAP
logging monitor discriminator FLAP
07-26-2013 10:53 AM
07-26-2013 02:43 PM
Hi Marvin
Thank you very much for this,It worked.
I had 12.4 (15)T14 where this feature was available. As per command reference this has been added 12.4(11)T onwards.
Rasika
07-26-2013 06:31 PM
You're welcome. I'm glad it worked out for you. It is a handy command.
Thanks for the rating.
