SWIM supports OS upgrade on 6513s or not 6509s
yjdabear
The hangup appears to be SWIM does not see the SUP module (and hence the bootdisk) on all the 6509s, but it sees them fine on all the 6513s. All the cat6ks are running CatOS 8.4(4). Is there any known issue between SWIM and cat6509?
SUPs on the 6509s:
4000-1000BaseX Supervisor 9 port WS-SUP32-GE-3B Rev. 4.5
1000-1000BaseX Supervisor 9 port WS-SUP32-GE-3B Rev. 4.1
2000-1000BaseX Supervisor 9 port WS-SUP32-GE-3B Rev. 4.1
SUPs on the 6513s:
SUPERVISOR32_6000
7-8 port 1000BaseX Supervisor module
The patch affects inventory, so it would address SOME of the inconsistencies between the platforms. However, the will still be some differences due to the different MIBs being used.
24 Replies 24
Joe Clarke
What version of RME is this? What version of the SharedSwimCAT package do you have?
RME 4.0.6. I see a SharedSwimCatSwitch at 1.0, but there's no device package update found when checking against cisco.com.
Upgradable one in the 6513s
MODULE : wssup32ge3b
MODEL : 8 port 1000BaseX Supervisor module
Image_Type : SUPERVISOR32_6000
SOURCE : bootdisk:
UPGRADETYPE : ACTIVE
The nonupgradable SUP in the 6509s, which translates to wssup32ge3b too, according to http://tools.cisco.com/Support/SNMP/do/BrowseOID.do?local=en&translate=Translate&objectInput=moduleType
MODULE : EntityVendorOIDType(.1.3.6.1.4.1.9.5.1.3.1.1.2.509)
MODEL : 1000BaseX Supervisor 9 port WS-SUP32-GE-3B Rev. 4.1
The package should be SharedSwimCAT, and the latest version is 1.4, and the Sup32-GE-3B is supported in this version.
Found it. I do have SharedSwimCAT 1.4. I've updated my previous post to include more info: The problem from what I see is the same wssup32ge3b (.1.3.6.1.4.1.9.5.1.3.1.1.2.509) is recognized by SWIM in the 6513 (slot 7 or 8), but not in any 6509 (slot 5 or 6).
What do you mean by isn't recognized? Please post a screenshot showing the difference between the working 6513 and the non-working 6509. I want to be sure we're on the same page.
I find the 6504s in the same boat as 6509s as well.
could you check if the failing devices are listed in RME with a status other then 'normal' (i.e. 'alias' or 'conflicting',..)
I found the problem. The 6506, 6509, and 6504 are instrumented differently than the 6513 when it comes to inventory collection. RME uses the CISCO-STACK-MIB when collecting the inventory from the 6513, but uses the ENTITY-MIB for the other switches. The ENTITY-MIB code is missing the new Sup module mapping. The bug is CSCsq40165.
Is there a fix available? If not, can one be expected any time soon, with a TAC case opened?
The bug is scheduled to be fixed in RME 4.3. There is no patch right now. It may be possible for development to create one if you open a TAC service request.
Thanks! I have to ask for clarification though: Would development make the patch for LMS 2.6 (RME 4.0.6)?
They should. The change is trivial.
I'm also curious if the patch would address the RME reporting inconsistencies between 650Xs and 6513s, presumably due to the same instrumentation difference, or would it be a single-issue fix just for SWIM?
