Community Member
Switch PortUsage from UT-> Reports -> Report Generator -
Is it possible automate the exporting from cwcli into a csv file of the daily report of User Tracking -> Reports -> Report Generator -> Switch Port Usage?
"We use LMS 2.6"
1 REPLY
Re: Switch PortUsage from UT-> Reports -> Report Generator -
cwcli doesn't have anything to do with UT reports. There is also no way to generate the UT switch port usage report from CLI. So, while you can schedule the report to run, you cannot automate the export.
198
