Webcast-Catalyst9k
switches, routers and hubs
Hey I'm getting into switch and routers stuff, and I wonder if there is some way to know how many routers, switches or hubs are between 2 pc (server - workstation) in a given LAN, including hardware information like mac -addres 'casue I'm trying to figure out how works this network (it's realy a mess)
1 REPLY
Silver
Re: switches, routers and hubs
You are asking a very vague question that is too hard to answer.
You are asking for info on a sites set-up and there is no way to give you an answer without knowing the site.
For a small basic set-up you can have one router and one switch that is set-up for server and workstations.
You need to be more specific in the question on the information you are looking for.
96
