Community Member
sync archive problem...
When we try to sync the configuration archive I get the following error on all of our wireless devices:
CM0056 Config fetch failed for ACC_Wireless_01 Cause: CM0204 Could not create DeviceContext for 348 Cause: CM0206 Could not get the config transport implementation for 10.1.16.150 Cause: No operator available for this device Action: Check if required device packages are available in RME. Action: Check if protocol is supported by device and required device package is installed.
Anyone know why this happens?
1 REPLY
Red
Re: sync archive problem...
It could be that the device type is not supported in the RME version that your are running.
111
