Webcast-Catalyst9k
Sync credentials with newly discovered devices LMS 2.5.1
How can you setup LMS 2.5.1 to automatically populate newly discovered devices with the credentials that all the current devices use? Now that I have LMS integrated with ACS I want every new device to be manageable by LMS without having to add the credential under Common Services.
Re: Sync credentials with newly discovered devices LMS 2.5.1
You will need to manually edit the device credentials. LMS has no way to automatically populate all device credentials if they are discovered by Campus.
Silver
If you do an export to a .csv file and import this into a spreadsheet you can quickly find all devices that only have the RO community string.
If you have an editor that allows macro's you can update this file quite easily.
An import of this file and all new devices are updated.
(nevermind the "errors" it gives when you import)
Cheers,
Michel
98
