12-18-2006 04:24 PM
My current Syslog Buffer is 4096 bytes. The 1801 (fixed) is a Gateway router for a small LAN(4 PC's)has a light work load. To what level I can safely increase my buffer without impacting performance.
12-18-2006 09:54 PM
I'd say you can safely increase this to 1048576 (1 MB) which should be more than enough for one day's worth of messages. However, since you are already logging messages to a syslog server, why do you want a large on-router buffer?
12-19-2006 03:34 PM
Thanks for your reply. Reason for for larger buffer is syslog server is not on 24X7.
