08-31-2009 07:31 AM
I have installed a fresh copy of LMS3.0 on Solaris 10 but I don't get any syslog reports. When I go in var/log/syslog_info there are no messages in the file. Do I need to update anything else for syslog to get the messages in syslog_info?
Solved! Go to Solution.
09-09-2009 07:01 AM
09-09-2009 10:33 AM
Post the output of ps -efl and netstat -an.
09-09-2009 10:38 AM
09-09-2009 10:46 AM
09-09-2009 01:18 PM
Syslog is running, but not bound to udp/514. Post the output of:
svcprop svc:/system/system-log:default
09-10-2009 07:33 AM
09-10-2009 08:18 AM
This is what I thought. Your syslog service is not configured to allow remote message reception. Run these commands as root:
svccfg -s svc:/system/system-log setprop config/log_from_remote = true
svcadm refresh svc:/system/system-log
Then you should be receiving remote messages.
09-10-2009 11:08 AM
09-10-2009 10:51 AM
Try forcing a restart of syslogd:
svcadm disable svc:/system/system-log
svcadm enable svc:/system/system-log
09-10-2009 12:23 PM
That did it. It's working now.
Thanks a lot for all your help Joe. I knew you would resolve it.
