Community Member
Syslog Messages
I have the following set up on one of the switches here a Cat 6509 now running Cisco IOS.
Syslog logging: enabled (0 messages dropped, 18 messages rate-lim
, 0 overruns)
Console logging: level debugging, 2189 messages logged
Monitor logging: level debugging, 460 messages logged
Buffer logging: level debugging, 2255 messages logged
Exception Logging: size (4096 bytes)
Count and timestamp logging messages: disabled
Trap logging: level informational, 1776 message lines logged
Logging to a.a.a.a, 1776 message lines logged
When I go to CiscoWorks, Through
CiscoWork>RME>Syslog Analysis,
I do not get anything.
Please help.
When it use to run CatOS I could see these messages.
1 REPLY
Re: Syslog Messages
Can you check the syslog.log (Windows) or syslog_info (Solaris) file to see if the messages are making it to the log file?
If they aren't then there's a problem with syslog on the device or in the network.
If they messages are in the log file, then go to RME and make sure that the device is managed in the inventory.
If it is, then try to run a standard report to see if the messages appear.
230
