syslog purge
the last 2 weeks my syslog records default purge job failed. I got error log "[ Wed Sep 17 10:28:26 PDT 2008 ],ERROR,[main],Drop table failed:ASA Error -210: User 'DBA' has the row in 'SYSLOG_20080722' locked 8405 42W18
[ Wed Sep 17 10:28:27 PDT 2008 ],ERROR,[main],Failed to purge syslogs
[ Wed Sep 17 10:28:27 PDT 2008 ],ERROR,[main],Purge not successful. there is no duplicate job, and I don't know why it's lock. the rmeng.db size is close to 2gb. is that cause a problem. restarting dmgtd can help? thanks in advance.
1 ACCEPTED SOLUTION
Re: syslog purge
Something was holding a lock on this table. Since this table is from August, that lock is most likely stale. If there are no other syslog purge jobs scheduled or running, SyslogAnalyzer is a likely suspect. A restart of the SyslogAnalyzer alone may free this lock up. However, if it is Tomcat holding it, then you would need to restart dmgtd.
Re: syslog purge
Re: syslog purge
thank you J. stop and restart SyslogAnalyzer solve the problem. appreciated your help!!!
252
