Community Member
syslog question (Catalyst 2950, IOS 12.1)
Hello Everyone,
New to switches here, so please be kind if this is a dumb question!
Is there any way to configure the switch to output a message when the startup-config changes? For example, make some changes to the running-config, and then issue "copy run start" command.
Thanks!!!
Community Member
Re: syslog question (Catalyst 2950, IOS 12.1)
you can use the config-copy MIB or use LMS RME automated action (run script if CONFIG syslog message is generated)
Community Member
hi there,
thanks for your reply. the thing is we don't see anything about the changes in startup-config from the result of "sh logging".
we have tried all the logging trap levels. any idea?
thanks!
142
