Community Member
syslog time on device is incorrect
Company switches display incorrect time value on log buffer, although they are synchronized with NTP server:
TNSWAGCS01013#sh log
(truncated)
Apr  5 14:20:40.188: %SYS-5-CONFIG_I: Configured from console by wassim on vty0 (10.100.7.2)
Apr  5 14:20:47.360: %LINK-3-UPDOWN: Interface FastEthernet0/11, changed state to down
Apr  5 14:20:48.752: %SYS-5-CONFIG_I: Configured from console by wassim on vty0 (10.100.7.2)
the clock value is correct:
TNSWAGCS01013#sh cloc
15:21:09.573 CET Thu Apr 5 2012
TNSWAGCS01013#
TNSWAGCS01013#show ntp statu
Clock is synchronized, stratum 9, reference is 10.100.254.1
nominal freq is 119.2092 Hz, actual freq is 119.2090 Hz, precision is 2**17
reference time is D3282603.42950715 (15:09:07.260 CET Thu Apr 5 2012)
Any idea?
Wass
Everyone's tags (4)
1 ACCEPTED SOLUTION
Blue
Re: syslog time on device is incorrect
Do you have something along the lines of "service timestamps log datetime localtime show-timezone" configured? If so, what does it look like exactly?
Blue
Community Member
Thanks, your hint helped me figure it out. In fact, I should have configured the following line: service timestamps log datetime msec localtime"
Problem solved.
Wass
770
