syslog trap.
i have downloaded kiwi syslog windows daemon. now how do i configure my 2851 router to send(syslog) message to it ? plz. give me deatils of commands.
thanx
Hall of Fame Super Silver
Re: syslog trap.
Sunil
The command to use is logging
Rick
Re: syslog trap.
hi i did all as u suggest , but on message has been registred on my kiwi server, is thr issue of time syc. issue between devices ?
Re: syslog trap.
Sunil
While it would be good to sync time between the router and the kiwi server, I doubt that the time mismatch is causing this issue.
Probably the first thing that I would do is to verify IP connectivity between the devices. On the router can you ping the address that you configured as the kiwi server - and verify that what is configured is the correct address for the server? (If you have configured logging source-interface then do an extended ping to the kiwi server and specify the source address of the ping to be what you have configured as the source address for logging).
If the ping is successful then we would need to look at something else as the cause. It would be helpful if you would do the show log command and post the output of the first group of lines which show how logging has been set up.
It might also be helpful if you would do "show run | include log" and post that output.
Rick
128
