Community Member
Syslog
How do i enable my RME to receive syslog mesaages from devices.
I have configured all the devices in my network to send syslog messages to RME,but each time i make a change on my box in message is sent.
Why did i go wrong,please let me know.
Thanks for your reply.
Re: Syslog
Nothing needs to be done in RME. You need to make sure your devices are sending messages with a facility of local7 to the RME server.If the devices are not sending messages, then you need to double-check your config. In general, this is all you need:
logging 10.1.1.1
logging trap info
logging facility local7
Community Member
Re: Syslog
Where do i get to check this.
Re: Syslog
Do a show run on the device. You can also see this by doing a show logg.
Community Member
Re: Syslog
Do I need to configure all the three statements or just the first statement will do the work.
Please reply,thanks
Re: Syslog
Technically just the first since the other two are default. As I said, do show logg to see what the current syslog parameters are.
117
