SyslogAnalyzer not starting after changing NIC's ip address
We have a machine installed with LMS2.5.1 with dual NIC cards. We have made necessary changes to the gatekeeper.cfg. All have been working fine and we are able to receive Syslog. However, we need to change the one of the NIC card ip address. We have reboot the LMS server and the SyslogAnalyzer has failed to come out. The following message appeared when we tried to pdexec SyslogAnalyzer:
Microsoft Windows [Version 5.2.3790]
(C) Copyright 1985-2003 Microsoft Corp.
C:\Documents and Settings\Administrator>pdshow SyslogAnalyzer
Process= SyslogAnalyzer
State = Never started
Pid = 0
RC = 0
Signo = 0
Start = N/A
Stop = Not applicable
Core = Not applicable
Info = Not applicable,
C:\Documents and Settings\Administrator>pdexec SyslogAnalyzer
ERROR: cmd failed. Server reason:
Can anyone advise how to resolve this issue?
  • Network Management
Re: SyslogAnalyzer not starting after changing NIC's ip address
Assuming all you changed was the IP address, and the hostname is still the same as when LMS was installed, then there is nothing else that needs to be done from the LMS side.
The fact that the SyslogAnalyzer process state is "Never started" means that one of the processes on which SyslogAnalyzer depends did not start. SyslogAnalyzer depends on the following:
EssMonitor
RMEDbMonitor
CTMJrmServer
jrm
Find out which of those have also not started. It would be best to paste the entire contents of pdshow for diagnostic purposes.
attachment show the pdshow output. Pls advise and thanks.
jrm is in a waiting to initialize state. This can happen if the hostname of the server was changed, or if the System Identity User is misconfigured. Please provide the NMSROOT\log\jrm.log.
Pls advise and thanks. Attached is the jrm.log.
It looks like there may be a race condition at work here. What are the CPU and memory specs for this server?
Pentium 4
2.4 GHz
1GB ram
The problem only happen when we change the ip address of one of the NIC card. The ip address of the other NIC card is not changed.
This is the problem. You MUST have 2 GB of RAM on this server for the product to start correctly. This is even without any managed devices. You also have DFM installed, so you require a multi-CPU machine.
Given these stats, your choice is either to install another 1 GB of RAM, or uninstall DFM. If you choose to keep DFM, you will also need to add at least one more real CPU (or core) for performance purposes.
I shall tried to uninstall the DFM to see if this resolve the problem. Shall post any updates.
277
