Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Syslogs on Cisco Prime Infrastructure 2.0
Dear all,
Does the Syslogs Server work on the verion 2.0 of the Cisco Prime Infrastructure?
Is the issue about syslogs server on version 1.3 resolved on the version 2.0?
Hi ,
Yes syslogs server work on verion 2.0 of the cisco Prime Infrastructure.
Are you referring to the problem of not seeing all the syslogs in PI ?
Confirm it.
Thanks-
Afroj
[Do rate the useful post]
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
thank you AHMAD,
Yes, i'm refering about the problem of not seeing all syslogs in Cisco PI 1.3
Apparently Prime 2.0 doesn't support all the features of LMS 4.2. So Prime is not able to display all syslogs .
I heard complete syslog support wil be there in  PI 2.1
Thanks-
Afroz
249
