09-18-2013 12:16 PM
I am currently trying to learn the TCL Language for use on IOS. A simple script I created is below:
The script works fine on a 3750 but fails on a 6509. Any ideas ? ?
Thanks!! KEV
proc validate {args} {
foreach address $args {
set output [exec "ping $address"]
#puts $output
regexp {.*Success rate is (\d+) percent \((\d+)\/(\d+)\), round-trip min/avg/max =\s+(\d+)\/(\d+)\/(\d+)} $output COMPLETE perc sent recieved min avg max
puts "ADDRESS:\t$address"
puts "PERCENT:\t$perc"
puts "SENT:\t\t$sent"
puts "RECV:\t\t$recieved"
puts "MIN:\t\t$min"
puts "AVG:\t\t$avg"
puts "MAX:\t\t$max"
puts \n
validate172.16.35.12 172.16.3.143 192.168.4.4
LAB_3750(tcl)#validate 172.16.35.12 172.16.3.143 192.168.4.4
ADDRESS: 172.16.35.12
PERCENT: 100
SENT: 5
RECV: 5
MIN: 1
AVG: 3
MAX: 8
ADDRESS: 172.16.3.143
PERCENT: 100
SENT: 5
RECV: 5
MIN: 1
AVG: 2
MAX: 8
ADDRESS: 192.168.4.4
PERCENT: 100
SENT: 5
RECV: 5
MIN: 25
AVG: 30
MAX: 34
LAB_6509(tcl)#validate 172.16.35.12 172.16.3.143 192.168.4.4
can't read "perc": no such variable
LAB_6509(tcl)#
Solved! Go to Solution.
09-19-2013 12:07 PM
This is what I thought. Tclsh doesn't work with command authorization. EEM does, however. Your script could be updated to this to work with EEM:
::cisco::eem::event_register_none
namespace import ::cisco::eem::*
namespace import ::cisco::lib::*
if { [catch {cli_open} result] } {
error $result $errorInfo
array set cli $result
array set arg_einfo [event_reqinfo]
cli_exec $cli(fd) "enable"
foreach aname [array names arr_einfo -regexp {arg[0-9]+}] {
set address $arr_einfo($aname)
set output [cli_exec $cli(fd) "ping $address"]
puts "MIN:\t\t$min"
puts "AVG:\t\t$avg"
puts "MAX:\t\t$max"
puts \n
catch {cli_close $cli(fd) $cli(tty_id)}
You register this script my copying it to disk0:/policies, then configure:
event manager directory user policy disk0:/policies
event manager policy validate.tcl
Also configure:
event manager session cli username USER
Where USER is a AAA user authorized to run the ping command.
Then run it using:
event manager run validate.tcl ADDR [ADDR] ...
09-18-2013 02:21 PM
Post the output of the ping command on the 6500. The regexp is not matching and that likely means the output is different between the two devices.
09-19-2013 05:55 AM
Below is output from the Pings on both types of gear. I am not a regex guru, but I checked it against the both Ping outputs, using RegEx Coach and it appeared to match OK, but who knows...
3750
LAB_3750#ping 172.16.35.12
Sending 5, 100-byte ICMP Echos to 172.16.35.12, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/4/9 ms
6509
LAB_6509#ping 172.16.35.12
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/2/4 ms
One other difference I notice between the two environments is the the 3750 drops me into a +> shell, immediatly after I paste in the script, while the 6509 seems to keep me in a (tcl) prompt. It also fails, in the same manner, if I launch it from a TFTP Server.
LAB_3750(tcl)#proc validate {args} {
LAB_6509(tcl)#proc validate {args} {
LAB_6509(tcl)#
LAB_3750_CODE: 12.2(44)SE3
LAB_6509 CODE: 12.2(33)SXI4a
Thanks for the help!!
09-19-2013 08:31 AM
If you print $output on the 6509, what do you see? You might want to consider switching to EEM Tcl to give you better control over the CLI sessions.
09-19-2013 09:18 AM
This just gets more and more strange...
I enabled the "puts $output" line and executed the TCL script. On the 3750, all was well, in that it showed the Ping results. On the 6509, I got a Command Authorization Failed message. I verifeid that I have Priv 15 credentials (one would hope, in order to even run these scripts). I see error messages in the Failed Attempts in ACS, from this host, each time I executed it..I compared the AAA sections of the configs and they match.
Command authorization failed.
LAB_6509(tcl)#
09/19/2013,11:55:47,Author failed,,Default Group,async,,User unknown,,tty2 | |
09/19/2013,12:00:28,Author failed,,Default Group,async,,User unknown,,tty2 |
Now, I have to admit, I have yet to even look into EEM or EEMv3, but I will do so.
09-19-2013 12:07 PM
puts "MIN:\t\t$min"
puts "AVG:\t\t$avg"
puts "MAX:\t\t$max"
puts \n
Also configure:
Then run it using:
09-19-2013 02:03 PM
Thanks a ton for your help!!
I still can't understand how AAA allows the script on one type of hardware and not the other (3750 vs. 6509), but that may be for another time...
I will look into this option further, especially as I come up with ideas to leverage this technology, in order to enrich the network monitoring capabilities currently in place.
