TDM PW related MIB for MWR?
j.cazecuteiro
I'm trying to look for a MIB of MRW 2941 that will enable me to identify the SAToP Attachment Circuits existing configuration at this router.
However I have not been able to identify the MWR MIB with such support. For hiT7600, that support seems (because MIB not yet available in Cisco SW Center) to be present at CISCO-IETF-PW-TDM-MIB, but I have not been able to find that same MIB for MWR 2941.
But even using the "MIB Locator" tool (http://tools.cisco.com/ITDIT/MIBS/servlet/index) I have not been able even to identify the correct "Platform Family", that I would expect to be "MWR 2900" or "MWR 2941" instead of only showning "MWR 1900" and "MWR 1941". Also, looking at MWR 2941 MIB Support (http://www.cisco.com/en/US/docs/wireless/mwr_2941_dc/software_config/guide/over.html#wp1157160) it is not clear what MIB would support it.
Question: can anyone pls tell which MIB or MIBs of MRW 2941 can I use to retrieve the SAToP TDM configuration?
Thanks in advance,
Rgds,
Jorge
8 Replies 8
Joe Clarke
I checked the MIBs supported in the latest release of code for the MWR2941, and there are no TDM MIBs.  I do not see a MIB which would provide the information for which you are looking.  Here is a list of the MIBs supported in mwr2941-iprank9-mz.124-20.MR2:
ADSL-DMT-LINE-MIB at revision 199809251000Z
ADSL-LINE-MIB at revision 199812211200Z
ATM-MIB at revision 199406072245Z
BGP4-MIB at revision 199405050000Z
BRIDGE-MIB
CISCO-AAA-SERVER-MIB at revision 200001200000Z
CISCO-AAA-SESSION-MIB at revision 199911160000Z
CISCO-AAL5-MIB at revision 200309170000Z
CISCO-ACCESS-ENVMON-MIB at revision 199808050000Z
CISCO-ADSL-DMT-LINE-MIB at revision 199903302127Z
CISCO-ATM-EXT-MIB at revision 199706200000Z
CISCO-ATM-PVCTRAP-EXTN-MIB at revision 200110010000Z
CISCO-BGP4-MIB at revision 200302240000Z
CISCO-BULK-FILE-MIB at revision 200108220000Z
CISCO-CALL-APPLICATION-MIB at revision 200305130001Z
CISCO-CALL-HISTORY-MIB at revision 200003280000Z
CISCO-CAR-MIB at revision 200002180000Z
CISCO-CAS-IF-MIB at revision 200801140000Z
CISCO-CDP-MIB at revision 200503210000Z
CISCO-CEF-MIB at revision 200601300000Z
CISCO-CIRCUIT-INTERFACE-MIB at revision 200005090000Z
CISCO-CLASS-BASED-QOS-MIB at revision 200701040000Z
CISCO-COMPRESSION-SERVICE-ADAPTER-MIB at revision 199608150000Z
CISCO-CONFIG-COPY-MIB at revision 200403170000Z
CISCO-CONFIG-MAN-MIB at revision 200608170000Z
CISCO-DATA-COLLECTION-MIB at revision 200210300530Z
CISCO-DIAL-CONTROL-MIB at revision 200505260000Z
CISCO-DSP-MGMT-MIB at revision 200506200000Z
CISCO-EIGRP-MIB at revision 200411160000Z
CISCO-EMBEDDED-EVENT-MGR-MIB at revision 200611070000Z
CISCO-ENHANCED-MEMPOOL-MIB at revision 200302240000Z
CISCO-ENTITY-ASSET-MIB at revision 199906021600Z
CISCO-ENTITY-EXT-MIB at revision 200104050000Z
CISCO-ENTITY-FRU-CONTROL-MIB at revision 200001130000Z
CISCO-ENTITY-SENSOR-MIB at revision 200601010000Z
CISCO-ENTITY-VENDORTYPE-OID-MIB at revision 200505050930Z
CISCO-ENVMON-MIB at revision 200804180000Z
CISCO-ERM-MIB at revision 200602110000Z
CISCO-ETHER-CFM-MIB at revision 200412280000Z
CISCO-FLASH-MIB at revision by
CISCO-FRAME-RELAY-MIB at revision 200501120000Z
CISCO-FTP-CLIENT-MIB at revision 199710091700Z
CISCO-H320-DIAL-CONTROL-MIB at revision 200602230000Z
CISCO-H323-TC-MIB at revision 200003100000Z
CISCO-HSRP-EXT-MIB at revision 199808030000Z
CISCO-HSRP-MIB at revision 199808030000Z
CISCO-IETF-ATM2-PVCTRAP-MIB-EXTN at revision 200007110000Z
CISCO-IETF-ATM2-PVCTRAP-MIB at revision 199802030000Z
CISCO-IETF-FRR-MIB at revision 200211051200Z
CISCO-IETF-NAT-MIB at revision 200103010000Z
CISCO-IETF-PPVPN-MPLS-VPN-MIB at revision 200304171200Z
CISCO-IETF-PW-MIB at revision 200302261200Z
CISCO-IETF-PW-MPLS-MIB at revision 200302261200Z
CISCO-IETF-PW-TC-MIB at revision 200302261200Z
CISCO-IF-EXTENSION-MIB at revision 200207240000Z
CISCO-IMAGE-MIB at revision 199508150000Z
CISCO-IP-RAN-BACKHAUL-MIB at revision 200608250000Z
CISCO-IP-STAT-MIB at revision 200112202300Z
CISCO-IP-URPF-MIB at revision 200411120000Z
CISCO-IPMROUTE-MIB at revision 200804010000Z
CISCO-IPSEC-FLOW-MONITOR-MIB at revision 200010131800Z
CISCO-IPSEC-MIB at revision 200008071139Z
CISCO-IPSLA-AUTOMEASURE-MIB at revision 200706130000Z
CISCO-IPSLA-ECHO-MIB at revision 200708100000Z
CISCO-IPSLA-ETHERNET-MIB at revision 200602080000Z
CISCO-IPSLA-JITTER-MIB at revision 200707240000Z
CISCO-ISDN-MIB at revision 200102090000Z
CISCO-MEMORY-POOL-MIB at revision 199602120000Z
CISCO-MVPN-MIB at revision 200402231200Z
CISCO-NBAR-PROTOCOL-DISCOVERY-MIB at revision 200208160000Z
CISCO-NETFLOW-MIB at revision 200503270000Z
CISCO-NTP-MIB at revision 200407230000Z
CISCO-OSPF-MIB at revision 200307180000Z
CISCO-OSPF-TRAP-MIB at revision 200307180000Z
CISCO-PAE-MIB at revision 200302260000Z
CISCO-PIM-MIB at revision 200011020000Z
CISCO-PING-MIB at revision 200108280000Z
CISCO-PPPOE-MIB at revision 200102200000Z
CISCO-PROCESS-MIB at revision 200301220000Z
CISCO-PRODUCTS-MIB at revision 200505051930Z
CISCO-QUEUE-MIB at revision 199508210000Z
CISCO-RAS-MIB at revision 199810091200Z
CISCO-RMON-CONFIG-MIB at revision 199804290000Z
CISCO-RMON-SAMPLING-MIB at revision 199805220000Z
CISCO-RTTMON-IP-EXT-MIB at revision 200608020000Z
CISCO-RTTMON-MIB at revision 200803240000Z
CISCO-SIP-UA-MIB at revision 200610050000Z
CISCO-SMI at revision 200011012246Z
CISCO-SNAPSHOT-MIB at revision 199508150000Z
CISCO-SNMP-TARGET-EXT-MIB at revision 200404010000Z
CISCO-STACKMAKER-MIB at revision 199610311200Z
CISCO-SYSLOG-MIB at revision 199508070000Z
CISCO-TBRIDGE-DEV-IF-MIB at revision 200204030001Z
CISCO-TC at revision 200702150000Z
CISCO-TCP-MIB at revision 200111120000Z
CISCO-VLAN-IFTABLE-RELATIONSHIP-MIB at revision 199904010530Z
CISCO-VOICE-ANALOG-IF-MIB at revision 200510030000Z
CISCO-VOICE-ATM-DIAL-CONTROL-MIB at revision 200211170000Z
CISCO-VOICE-COMMON-DIAL-CONTROL-MIB at revision 200610190000Z
CISCO-VOICE-DIAL-CONTROL-MIB at revision 200603120000Z
CISCO-VOICE-DNIS-MIB at revision 200005020000Z
CISCO-VOICE-ENABLED-LINK-MIB at revision 199905070000Z
CISCO-VOICE-FR-DIAL-CONTROL-MIB at revision 199903200000Z
CISCO-VOICE-IF-MIB at revision 200403040000Z
CISCO-VOICE-NUMBER-EXPANSION-MIB at revision 199906280000Z
CISCO-VOICE-URI-CLASS-MIB at revision 200210100000Z
CISCO-VPDN-MGMT-EXT-MIB at revision 200706040000Z
CISCO-VPDN-MGMT-MIB at revision 200601200000Z
CISCO-VTP-MIB at revision 199902251130Z
CISCO-WRED-MIB at revision 199707180000Z
DIAL-CONTROL-MIB at revision 199609231544Z
DS3-MIB at revision 200409080000Z
ENTITY-MIB at revision 199912070000Z
ETHERLIKE-MIB at revision 199908240400Z
EVENT-MIB at revision 200010160000Z
FR-MFR-MIB at revision 200011300000Z
HC-RMON-MIB at revision 199702120000Z
HDSL2-SHDSL-LINE-MIB at revision 200205090000Z
IANAifType-MIB at revision 200308070000Z
IEEE8021-PAE-MIB at revision 200101160000Z
IF-MIB at revision 200006140000Z
IGMP-STD-MIB at revision 200009280000Z
INET-ADDRESS-MIB at revision 200112170000Z
INT-SERV-GUARANTEED-MIB at revision 199511030500Z
INT-SERV-MIB at revision 199710030642Z
IP-FORWARD-MIB at revision 199609190000Z
IPMROUTE-STD-MIB at revision 200009220000Z
IPV6-FLOW-LABEL-MIB at revision 200308280000Z
ISDN-MIB at revision 199609231642Z
MPLS-LDP-MIB at revision 200108161200Z
MPLS-LSR-MIB at revision 200004261200Z
MPLS-TC-MIB at revision 200101041200Z
MPLS-TE-MIB at revision 200011211200Z
MPLS-VPN-MIB at revision 200110151200Z
MSDP-MIB at revision 199912160000Z
NHRP-MIB at revision 199908260000Z
NOTIFICATION-LOG-MIB at revision 200011270000Z
OLD-CISCO-CHASSIS-MIB
OLD-CISCO-SYS-MIB
OLD-CISCO-FLASH-MIB
OLD-CISCO-INTERFACES-MIB
OLD-CISCO-IP-MIB
OLD-CISCO-TCP-MIB
OLD-CISCO-TS-MIB
OSPF-MIB at revision 199501201225Z
OSPF-TRAP-MIB at revision 199501201225Z
PIM-MIB at revision 200009280000Z
Q-BRIDGE-MIB at revision 200601090000Z
RFC1213-MIB
RFC1213-MIB
RFC1231-MIB
RFC1315-MIB
RFC1381-MIB
RFC1382-MIB
RFC2982-MIB at revision 200010160000Z
RFC4087-MIB at revision 200505160000Z
RIPv2-MIB at revision 199407272253Z
RMON-MIB
RMON2-MIB at revision 199605270000Z
RS-232-MIB at revision 199405261700Z
RSVP-MIB at revision 199808251820Z
SMON-MIB at revision 199812160000Z
SNMP-FRAMEWORK-MIB at revision 200210140000Z
SNMP-MPD-MIB at revision 200210140000Z
SNMP-NOTIFICATION-MIB at revision 200210140000Z
SNMP-PROXY-MIB at revision 200210140000Z
SNMP-TARGET-MIB at revision 200210140000Z
SNMP-USM-MIB at revision 200210160000Z
SNMP-VACM-MIB at revision 200210160000Z
SNMPv2-MIB at revision 200210160000Z
SONET-MIB at revision 199810190000Z
SOURCE-ROUTING-MIB
TCP-MIB at revision 199103310000Z
UDP-MIB at revision 199103310000Z
VRRP-MIB at revision 200003030000Z
XGCP-MIB at revision 200508220000Z
Hello Joe,
Thanks for the list of MIBs supported by MWR 2941.
But I would like though to know how I can retrieve that same list from MIB Locator.
Up to now I had to  consider Release 12.4(19)MR2, Platform  Family=MWR1900 and Feature Set RAN OPTIMIZATION WITH ADV IP for searching for MWR 2941 supported MIBs (http://tools.cisco.com/ITDIT/MIBS/MainServlet?ReleaseSel=3361&PlatformSel=254&fsSel=1098) as I could not find Platform Family = MWR2900 or MWR2941.
Also, searching for the image suggested by you, i.e.,  Image Name = mwr2941-iprank9-mz.124-20.MR2 or mwr2941-iprank9-mz.124-20.MR2.bin results in "Invalid Image Name" error. And at MIB Locator I have not been able also to identify any 12.4(20)MR2 IOS release, only 12.4(19 and 16)MR2.
Request: could you pls provide the keywords to search at the MIB Locator for the MWR 2941 specific MIBs? Or is it the case that currently such information is not available via MIB Locator?
Rgds,
Jorge
Hello Joe,
Could you pls also provide a list MWR 2941 supported MIBs for the image MWR-2941-DC-ADVIPRANK9-M.bin, 12.2(33)MRA?
That will be the exact image and IOS version that I have to use for MWR 2941 routers.
Note: I have tried to use the MIB Locator but I'm not able to specify that exact IOS version or retrieve MIBs for that image.
Rgds,
Jorge
I have added support for this platform to the MIBs In Images tool, so you can send email to mii@external.cisco.com with the image name in the body, and you will get an email returned to you with the list of supported MIBs.
Hi:
I also worked on Cisco MWR2941,the version is below:
NATLIS_2941_3#show version
Cisco IOS Software, 2900 Software (MWR2900-ADVIPRANK9-M), Version 12.2(33)MRB4, RELEASE
SOFTWARE (fc1)
I also want to find out the direct relationship between E1 port and TDM(cem)model from MIB.which MiB can store the data of TDM ?
do you know where can find out the direct relation between "E1 0/1" and "cem 0/1" in Cisco MIB?
the reason is below:
as customer's need,we(CiscoMWR2941) need to add a function on configure
ATM or TDM(cem) mode to E1 interfaces and upload relative information
from MIB;
now,we can configurate these two modes by command.and we had already
found the direct relation between "E1 0/1" and "ATM 0/1" ,but we can't
find the direct relation between "E1 0/1" and "cem 0/1"(TDM).
####if set the mode of E1 to "ATM",
we can see from ifStackTable of IF-MIB:
IF-MIB::ifStackStatus.25.23 = INTEGER: active(1)
Here '23' is the ifindex of E1 0/1, '25' is the
ifindex of ATM0/1
then we can also see from ifTable:
ifIndex ifType ifDescri
23 ds1 E1 0/1
25 atm ATM 0/1
we could find the uping entry in ifdescri MIB entry
and know this E1 port which ifindex is 23 in ifStackTable is in ATM
mode.
####if set the mode of E1 to "TDM",then we can see from
if table:
23       ds1    E1 0/1
154     other   cem 0/1
we can't find the direct relation between "E1 0/1" and
"cem 0/1" as ATM mode. we had tried our best to resolve this problem,but
still can't find.
sun nan
Please start a new thread for your question.
Hello again,
I just wonder whether the DS1-MIB was mistakenly missing for the supported MIBs for mwr2941-iprank9-mz.124-20.MR2!
My understanding was that MWR 2941 did not support DS3 but only DS1, but I can see the DS3-MIB but not the DS1-MIB.
So, ins't DS1-MIB also part of the supported MIBs of MWR 2941?
Rgds,
Jorge
Mark Walters
FYI I just used that MIB (CISCO-IETF-PW-TDM-MIB) to pull TDMoIP / CEM counters from an MWR2941 running 15.1(3)MRA2.
OID is 1.3.6.1.4.1.9.10.131
cheers
mark
