TELNET AND RELOAD FROM LMS 3.0
I am using Cisco LMS 3.0.From the devicee centre,how can i reboot a switch and when i click on the telnet link , it fails as well ?
Any idea how can i reboot a switch from LMS 3.0 and what configuration you need to do to telnet to it from the device cetre ?Is there any way you can clear the telnet session from the device centre ?
1 ACCEPTED SOLUTION
Re: TELNET AND RELOAD FROM LMS 3.0
In order for telnet to work from Device Center, you need to have a telnet:// URL handler installed in your client's browser. On Windows, IE typically launches telnet.exe.
To reload a device, create a Reload Netconfig job under RME > Config Mgmt > Netconfig. Just select your device or devices, then select Reload from the task list.
Both solutions worked.
Legendary
Well Done.
Arif
183
