Telnet Does Not work from Cisco View
I have installed CiscoWorks LMS 3.2 on Windows 2008 server. When I try to execute Telnet command from Cisco View page, system open Internet Browser instead of any of Telenet application. How I can configure so that either system should open Telnet client or Hyper Termianl?
1 ACCEPTED SOLUTION
Re: Telnet Does Not work from Cisco View
If you're using Internet Explorer 7 or 8, you will need to re-enable the telnet URI handler before telnet:// links will work.  You can Google how this is done (and how to use a telnet application other than telnet.exe), or have a look at http://www.securenetterm.com/html/telnet_handler.html .
Dear Joseph,
Thanks for your support, yes, now it is working.
358
