TFTP between different devices
Is it possible to load a TFTP file from a 2600 to a 3800? Is the text config file the same as the tftp file(can you edit the tftp file)? Is there other ways to save a config so that it can be loaded automatically incase of failure?
  • Network Management
1 REPLY
Red
Re: TFTP between different devices
Yes you may, but you would have to go via a tftp server first
The config is simply a text file, and it can be edited
In your case, since one is 2600 and the other is a 3800, I would say you will have to modify it a bit
86
